I've been reading this site for a while. What a wealth of information! I have been searching for some specific information for the better part of the day and have found bits and pieces of what I am looking for but not specifically or entirely.
So, I'll describe my situation and outline my questions and see if y'all can help
I apologize in advance for the novel....
I have access to as much free wood that I am willing to cut and haul. The problem is most of it is Cottonwood or Poplar. I know it's not a desired wood but I paid nothing for it except for a couple gallons of gas in the chainsaw and my buddy's splitter. I have 3 cords of pretty well dry barkless Poplar cut,split and stacked, and 1 cord of Ash that is only about 6-month seasoned which I'm saving until next year. I don't have easy access to the better mountain softwoods such as fir and larch(since I'm in the plains of eastern MT), so I'm using what I have easiest free access to.
I am on a tight budget and wanted wood heat for 2 reasons: I love the ambiance and warmth of wood heat, and for the opportunity to offset the cost of propane for my furnace by burning free firewood. I grew up burning wood and loved it The 70's-era masonry fireplace in this house was negatively efficient, and after several attempts to get some heat out of it by using some exhaust tubing and a squirrel cage blower I had in the garage last year, I conceded defeat and bought an EPA insert this year.
The insert I purchased is an inexpensive Century unit from Ace Hardware:
http://www.acehardware.com/product/index.jsp?productId=3706810 It's nothing fancy, but we're going for a budget friendly setup. I also bought a 15' Flex King stainless liner and insulation kit from a place online and installed it all myself after many evenings of reading on here and watching YouTube videos.
I did the 3 break-in burns as prescribed in the owners manual: 2 at 250* “as indicated by an insert-top thermometerâ€, and 1 at just at tick under 450* (couldn't seem to get it to go over about 430).
Today is the first day where I have been able to burn all day, and have had some questions come up as I'm doing so.
1)Where should the insert-top thermometer be placed? The insert sticks out from the faceplate about 6†and I have a magnetic thermometer on the top of the stuck-out area, offset to the left a little. Is this a good position for it?
2)How do I get a hotter burn? I suspect because I'm burning Poplar and it's a fast-burning, low-output species of wood, but is there anything else I may be doing wrong? The technique I'm using is: some kindling with a piece of newspaper to get it started, air wide open, door cracked about an inch for about 3-5 mins while the fire gets good and hot. Then add small split and keep door open for another 3-5 mins, then close door, leaving air wide open. Once that split gets going good, I add another split, and leave the air wide open for another 15-20, add a 3rd split, air wide open for another 5. By this time the fire is HOT and the thermo reads ~400. From there, I start dialing the air back gradually to about ¼ to 1/8 open. I'm getting plenty of heat into the house with the thermometer reading between 300 and 400, but at the same time I don't want creosote buildup either. Accodring to the thermometer, anything above 250 is out of the “danger: creosote†zone. The inside of the firebox seems very hot: the baffle tubes are glowing orange and the flames around the baffle are burning bright blue, indicating good secondary combustion.
3)What is the best air control method throughout the entire burn from begining to end? I have found that wide open until the thermometer reads 400ish (where it usually hovers and won't climb above) Then I dial it back to about ¼ to 1/8 open. And let it burn slow and hot refueling as necessary. If I close it completely it seems to want to suffocate the fire and the temp starts to drop.
4)When it gets too hot in the house and it's time to shut 'er* down what's the best method to do so.... but at the same time limiting smoldering/creosote? The few times I've done it I just close the air all the way and scatter the coals.
5)What about blower operation? This stove's blower is 100% manual. Obviously I wait for the stove to build some heat to turn it on, but when I'm shutting it down, should I turn the blower off or leave it on? What about on overnight burns? Will the blower affect flue temps and/or creosote buildup?
I'm loving this insert, and for less than $1500 for the whole setup and heating my home with free wood, I couldn't be happier. I know it's not the fanciest, biggest or most high-tech insert, but for the price, I simply can't complain.
Thanks for any and all input.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
