Special gloves and other needs
tmsjava
18
Massachusetts
I assume you can open the hopper to pour more pellets in while the stove is running (we've only run it a couple of times since we got it). In that case, we'll need "heat resistant" gloves, right? Any special kind to touch the hopper while it's hot? (I can't use a regular kitchen oven mitt, right?)
We also got brushes and long rods that connect to clean out the pipes. Some glass cleaner and the stove came with a scraper. Will order an ash vac soon.
Do I need anything else for cleaning/maintaining?
Thanks,
T.
Filling the hopper won't require gloves. Cleaning the burn pot will. I wear a pair of Ove Gloves for that job. I just use an ordinary shop vac when I need to do a deep clean after the stove has gone stone cold.
Really?? Doesn't the hopper get hot? It's all metal. And did you mean regular "oven" gloves for the other? Ohhh, I see there's actually something called an "Ove Glove"! haha
I don't have the exact same stove as you so I can't say for sure. I would expect it gets warm but not hot.
Yep, the Ove Glove, that's what I use.
Thanks,
T.
It does get up to room temp most of the time no gloves needed
and yes you can fill the stove with it running . I only use a reg
shop vac with a dry wall dust bag and only when the stove has
been turned off and dead cold
Reactions: tmsjava and jackman
what he said...:cool::cool:
As time goes on, you will assemble a kit of tools needed to clean your stove, and a routine to do it. Lots of people use a regular shop type vacuum with various drywall filters. I bought a love-less ash vac when I bought my first stove over 20 years ago. Different strokes for different folks I say. I also use a cheap pry bar to scrape the burn pot. Mine has a long handle so I can scrape without gloves. A two inch paint brush is also a great thing to have to brush the firebox.
Reactions: tmsjava
good tips..
here's my mighty scraper i use when the flames are kickin.xtra long for that purpose.
  • Special gloves and other needs
There's also some pellets still in the hopper (not a ton). I should probably scoop them out and put them into a closed container for the summer, right? I read somewhere some people put a can of damprid in the stove over the summer....??
think i posted somewhere about damprid..lot of stove owners use it..i get about 1/2" of water in the container by the time burning season starts.
also good idea to put remaining pellets in a closed container or bag...
now, some here will chime in that it's all overkill and they just shut the stove off, leave the ash/pellets in it, and take care of cleaning next season and that works fine for them.
something about the ash absorbing moisture etc... but i have also read opposite reactions also to doing it that way whereas some stoves got rust....so who do u listen to?
just do what makes you feel comfortable about maintaining your stove..Personally .i never wanted to wait till i got rust and wished I should have done some prevention.
Reactions: jackhammer
If the lid to the hopper of a P43 gets too hot to touch safely, you have a bigger problem. I have an old set of welding gloves that I use for messing around the inside of the stove if it is still hot.
I leave pellets in the hopper and haven't had any issues even with the humidity we get here in NH. YMMV.
I was always ocd about the stove being cleaned at the end of the season. Usually jumped right on it. Now not so much. I cap the vent pipe with a rubber fernco cap which you can get at Home Depot. Disconnect the air supply and put a damp rid in the firebox just because. This buys me some time.
Reactions: bogieb
