Hello
I am trying to source a good replacement for the Breckwell C-E-033 squirrel cage room blower. Does anyone know what the difference is in the new improved breckwell C-E-033A?
Specs on motor label
Made by
Fasco Industries, Inc.
Motor Division
Assembled in Mexico
No 702112105
v115 Hz 60 A1.5
Breckwell Part # C-E-033
I called Breckwell tech support and they told me it is 120 CFM. However they could not tell me the RPM ! ! !
The mounting flange is 4-3/8" across the top and 4" down the side. Which is common.
See 1st pic below
First, I found this B24220 with a nice dust screen on the intake.
http://www.cshincorporated.com/product_info.php/products_id/4053
It is rated at 135 CFM so it should push out just as much air or more!
The RPM spec on the site says 2600 RPM but on the motor label it says 3200 RPM ! ! !
See Pic 2 - blower on right side.
I tried two of these blowers but the amount of air it was pushing out did not come close to the original! ! ! What's up with that?
Made by
Motor Division
N. 70214399 Type U21 T.P. AO
115v 50/60 Hz
1.3A 3200 RPM 1/25 HP
Model B24220
LR36496 M2412
The only visual difference btween the above motor and the Breckwell, is the above motor has the motor cooling fan mounted in front of the motor, next to the squirrel cage. the Breckwell motor has the cooling fan mounted behind the motor next to the back cover! ! !
Then I got an Englander convection blower from a 25-PDVC. It is smaller in size than the other two but rated at 140 CFM ! ! ! When I tested it, we could feel much more air coming out? See Pic 2 - blower on left side.
So any ideas, what convection blower to use? The B24220 is all show and no go!
This 150 CFM grainger blower #1TDR6 is split capacitor and will not work!
http://www.grainger.com/Grainger/ww...ch&Ntt=1TDR6&N=0&GlobalSearch=true&sst=subset
Made by
Motor Division
Assembled in Mexico
No 702112105
v115 Hz 60 A1.5
See 1st pic below
Made by
Motor Division
115v 50/60 Hz
Model B24220
LR36496 M2412
