What are my options for 1 1/4" or 1 1/2" insulated pipe for an OWB? I see Central Boiler has 1 1/4" ThermoPEX. Are there others?
mhvfd said:Again, I used the double wrap because of pricing and flexibility. But no matter what kind of piping you use; a) none of it is easy to work with. b) dig it as deep as you can go.
BrownianHeatingTech said:Microflex
I've used a few different sorts, and I've never dealt with another one that showed this kind of quality, yet.
The insulation is actually foamed pex, according to the specs. Use their head loss chart, though, because it's listed to flow better than similarly-sized pex by some other manufacturers.
Joe
mhvfd said:No doubt, the foam may be the way to go, however based on the length of pipe you need to go and how much muscle you got, double wrap surely keeps my home cozy and warm. If someone can tell me the DT value at 150' of foam versus double wrap, I beg to differ if it makes any real difference. I thought the "easy lay" was a hard, imagine 300 feet of thermopex. Heck, does it even come in that length?
leaddog said:mhvfd said:No doubt, the foam may be the way to go, however based on the length of pipe you need to go and how much muscle you got, double wrap surely keeps my home cozy and warm. If someone can tell me the DT value at 150' of foam versus double wrap, I beg to differ if it makes any real difference. I thought the "easy lay" was hard, imagine 300 feet of thermopex. Heck, does it even come in that length?
https://www.hearth.com/econtent/index.php/forums/viewthread/31939/ Here is a thread comparing, done with quality insturments, apples to apples, by Heaterman.
I don't have documentation but from personal experience, and I've done several kinds, foam is the way to go.
leaddog
yes a CB dealer should be able to sell you up to 800' in one piece, special order longer possibly, or sell you water (heat) tight splices also. for 300' you would loose 3-4 degrees with thermopex. 400' is the most I have heard of for a OWB thermopex run.mhvfd said:I thought the "easy lay" was a hard, imagine 300 feet of thermopex. Heck, does it even come in that length?
leaddog said:digging deeper doesn't stop the heat loss it just takes it longer to reach the top.
leaddog said:If the insulation value isn't there you still lose the btu's. foil/bubble/bubble/foil gives some insulation but no where near the value of foam.
flyingcow said:The microflex looks like the stuff to use. Pretty neat looking stuff. Thanks for the link, should have used that stuff a few months ago. Not that I'm going to buy any, but is the inch and 1/4 stuff vermuch more than the thermopex?
ken999 said:1 1/4" ThermoPEX is going for $18-19 a foot.
ken999 said:...Makes we wish I was a little closer to NH Joe.
How does the Microflex compare to ThermoPEX for insulation quality? It sure looks more flexible, which would be a real boon for a temp. winter install like I am facing.
