I want to replace the lame plug with o-ring on my splitter (not sure of size at this point - it's a HF.)
It would have to be closeable for transport.
Thanks.
If you can, I'd use a standard hydraulic adaptor fitting of smoe sort and run a hose up high somewhere, then use a filtered breather. Every cycle in & out, the displaced cylinder rod volume means air goes in & out of the breather. Filter it well. keep it up high to minimize vapor and liquids carrying out. and minimize slosh in tranport.
I would not close it off, (unless it was truly a plug already) as the tank pressure will build up as tank heats, but more importantly go to vacuum as tank cools. Can cavitate the pump, or draw air in pump or cylinder shaft, under certain conditions.
Thanks for the info.
To close it off would be for transport and storage.
The plug that came with the splitter has an o-ring with covers an air hole.
The o-ring gets soft, lost, etc. Plus there is no filtering.
so you have to roll the oring back and forth over the holes in the side? hokey for sure........
any industrial or auto store or hardware will probably have oring assortments. Just make sure it is nitrile/buna N, oil suitable. some hardware stuff is neoprene for water.
but I'd use the breather... just extent it up a bit and you won't likely need to shut it off.
Don't wanna close it off for storage. You want to let it breathe so moisture can get out. Also, o-rings are cheap. If you can't get em' local you can get what you need from McMaster Carr and get em in Viton.
Just working on that today, it's a 3/4" NPT pipe thread, you can get standard schedule 40 elbows and such at any hardware store. I picked up a breather for it at my local hydraulic shop, $20, which may have been a bit pricy, but... It was also much bigger around than the original plug. I put a 2" nipple in the fill pipe hole, then a 45* elbow, which makes the opening mostly vertical, and put the breather cap in that. Looks a bit hokey, but should work a lot better.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
