Quick Question,
We're honing in on a stove purchase for our basement, but ran into a question about vertical clearances on the PE Alderlea T6 (http://www.pacificenergy.net/alderlea/pdfs/AL6B-030512-20.pdf)
Is there a vertical clearance requirement? If you read the documentation, on page 9 it seems to indicate that you need 56 1/2" from stove top to ceiling. What doesn't add up is that it also says that you need a 7' ceiling minimum. The stove itself is 29 13/16" tall, which means if the 56 1/2" clearance number is true you would need (56 1/2+29 13/16=86 5/16") ceilings, which is greater than 7', especially if you add the thickness of the hearth pad.
My net question is...if I have 7'+ ceilings throughout the basement (right above the stove there are two ceiling heights as a knotty pine covered hot air vent is over about 1/2 of the hearth leaving a 7' 4" ceiling height with 8' 3" ceiling heights elsewhere) am I okay? FYI if it matters...this isn't a mobile home install.
Thanks,
Justin
Thanks,
Justin
