Some wood shed "terms" & my understanding of the definitions
bogydave
8,426
So Cent ALASKA
Some "terms" Ive learned here.
May need to add to the list.
"THE WOOD SHED" TERMS & DEFINITIONS
Rounds: Cut to usable length pieces of a log, prior to splitting
Splits : Split rounds,, some of the wood is exposed, split to desired thickness, sizes. Smaller the "Splits" faster it dries
Stack: Semi neat stacks of rounds or splits in a row/rows
CSS: Cut, Split & Stacked firewood
Seasoning Stack : Stack of split wood, typically long single row or rows on pallets (off the ground) with some space between rows for air circulation, in an open sun & wind location. Left for at least 1 year (2+ for oak)
Pile A random pile of splits or rounds thrown in a pile prior to stacking (if left in a pile for over 2 years "compost" for many types of wood)
Cord: 128 cubic feet of wood, typically: 16" long, stacked tight in 3 rows to measure 4' X 4' X 8'. (actually 80 - 90 cubic feet of wood & the rest of the cubic area is air)
Face cord: 1 row of stacked wood, 4' high X 8' long. Cubic area varies by the length of the rounds/splits. Typically 16" & 1/3 of a cord (42.666... cubic feet, 26.6 cubic feet of wood +16 cub.ft air))
Wood shed: A supported roof structure to keep rain & snow off the stack/s of wood. What you build after you get tired of chasing, replacing, securing tarps or covers or when you need to find you wood after a big snow storm. Typical minimum size, holds one full, burn season's CSS , dry ready to burn wood.
Tarp covered wood: The tarp is just covering the top,not the sides to allow air to help keep it dry. Also the tarp is to be secured well enough that it rips, shreads or a corner is still attacked after a good wind storm. Chasing tarps around the neighborhood is not exceptable.
Seasoned wood: Wood that is less than 20% moisture content/ready to burn. Typically 1 year "+", split & stacked in a "seasoning stack". (2 years for Oak) The wood will reach equilibrium with the moisture in the surounding air. (Not typically sold by wood sellers, some have a different definition i.e.: split at least 2 days ago)
Shoulder wood: Wood for spring & fall when a good hot fire is not needed 24/7. Sometimes short ends, uglies, mis-shaped or lower BTU wood.
Horizontal splitting: Splitting wood with the piece of wood to be split orentated horizontal, usually on a hydraulic powered splitter about waist high.
Vertical splitting: Splitting wood with the piece of wood to be split orentated vertical. Most manual splitting is vertical. Many hydraulic splitters can be used verticlal. "The easy/only way if you have a milk crate to sit on" BWS
BTU: British Thermal Unit, used to measure the heat energy of wood. BTU of wood "by weight" is the same for all wood types. A pound of oak has the same BTUs as a pound of aspen (0% moisture content).
Btu/cord: thermal values based on specific gravity of 80 cubic feet per cord. Oak is denser than aspen so oak has more BTUs/cord. BTU/cord charts typically use 12% moisture content.
To hopefully clarify:
"seasoned" means whatever the speaker wants it to mean, usually without clarification; it's a tool for suckerage.
When talking MC, you really should clarify basis- usually DRY basis.
No such thing as standard piece length (like your 16") in specification of a cord. You can ADD whatever spec gets it done for you.
Rounds can be as bucked, to any length from barely manageable to final. People's methodologies vary.
What does "punky" mean? I have never heard that term before related to wood.
usually means rotten. Wood can be in various stages of "punk". Some still worth burning, others are just not worth it.
You could also add 'Rick' to your list. A Rick is half a cord 8' L X 4' H X 24" D
The term is pretty common in the south. Most of the time you will find that a Rick is
being sold that is just a face cord and not a true Rick. Thereby giving way to all the
fuss about true Ricks and Cords.
Rick = Fossil
Top Down -- a method of fire starting where the kindling is on top of the larger wood vs. more traditional methods of fire starting where the kindling and tinder is at the base of the larger wood
North-South/East-West -- the way the firewood is oriented in the firebox
Buck -- to cut up longer length wood into wood sized to fit in the firebox of the stove
Punks -- punky wood which may or may not be suitable for burning
Chunks -- shorter sized wood which some folks set aside for burning in the shoulder season although they can be burned at any time
Uglies -- wood that may be twisted, gnarly, have crotches, etc. either from natural growth or due to splitting
Junk Wood -- wood that may be not as desirable to burn due to the low BTU value or punkiness
Cat -- Catalytic combustor used by some stoves to achieve clean, long-burning times
Secondaries -- Secondary burn seen in stoves using secondary burn technology to achieve clean, long burning times
Slab Wood = Outer edges of logs removed (slabs), generally from a sawmill operation
CL = Craigs List
Hardwood = Generally refers to deciduous species
Softwood = Generally refers to coniferous species
MC = Moisture Content, percentage of wood comprised of water
DHW = domestic hot water usually provided by a boiler and a hot water coil somewhere(either in the boiler itself or in a storage tank).
Storage = Typically a seperate unit of some sort that is well insulated and stores heated water that can be used for heat and/or DHW without needing to fire the boiler again.
Scrounge = To me, this is finding firewood without paying for it.
MM = Moisture Meter to help determine dryness of a split of wood. For me, it's usually confirmation of what I sorta knew already.
Husky = Husqvarna chain saw
Alaska Mill = attachment for the chainsaw that allows you to mill logs into dimensional lumber
B and C = Bar and chain
MDW = My dear wife
Noodling = Using a chainsaw to cut with the grain of a usually large round to make splitting easier
P&C = piston & cylinder
WOT = wide open throttle
rakers, drags = depth gauge on cutter link of chainsaw chain.
flippy caps = tool-less caps on Stihl fuel and oil tanks.
c/s/s = cut/split/stacked
muff mod = to modify your muffler
four stroking = a condition in which the engine is running rich, which causes it to sound "rougher" than that of a leaner "smoother" sounding condition. (More detailed definitions are available.)
Popple = poplar
Hedge = short for hedge-apple tree aka osage orange tree (Maclura pomifera)
Mac = McCullouch chainsaw
Jonny/Jred/Johnny Red = Jonsered chainsaw
Dolly = Dolmar chainsaw
Dolkita = Often a Makita saw modified with Dolmar parts
Creamsicle = orange and white Stihl chainsaws
Lots of good terms, acronyms & definitions,
Huskee 22 :: 22 ton , huskee log splitter, Vert or horizontal, made by speeco, tractor supply has them "on sale" late summer/early fall around $999 (maybe one for "The Gear")
Some body who is a good typer compile a list. (or cut & paster) who could do taht, dats nat mee :) Volunteers?
Get a list made, run it thru management & see if they want to make it a, sticky, run a pole, vote for best definition, simple & to the point definitions. Something like that may be useful.
Stay on topic for "the wood shed", may expand , one for "the gear".
Sticky is a good idea.
No to many HH fans here I suppose.
Halarious Heep
CSM....Chainsaw mill!
holz hausen
Wood house?
cold one.... beer a must have after stacking, splitting, bucking, or felling
Widow maker- tree or part of a tree that is in a precarious position offerring significant potential for bodily injury when cutting it.
VC- Vermont Castings
PPE- Personal protective equipment
Barber Chair- When a standing tree being cut splits vertically during the cut, and causes the top to detach from the trunk somewhere above the cutting point. Usually resulting in a large portion of the tree falling in an unexpected direction. example here http://www.youtube.com/watch?v=2YAf61zz5VU&feature=related
