Some small Questions about an Enviro Mini?
Don2222
9,146
Salem NH
Hello
Just grabbed an old Mini - MFD Nov 2006
Checked the manual and it does not say anthing about this.
1. Why is there a hole in the side of the hopper? See pics 2 & 3
2. What is the bracket on the back right corner for?
Holding some tool?
Is there anyway to increase the room blower speed above the heat level speed for each setting?
Can it be on full speed for the heat level settings below 5?
Also what is the difference between the Mini and the Mini-A?
Mini-A has everything the Mini has plus:
1. Newer Control Panel with Combustion and Feed Trim buttons for all heat levels.
2. A wider burn pot and liner to keep unburned pellets from bouncing out.
3. An ash pan with a round knob latch that latches.
The above can be put in the old Mini to make it run better.
Anything Else?
Mini-A Manual
http://www.enviro.com/images/manual...C-13850 Instruction Mini A Owner's Manual.pdf
Old Mini Manual
http://enviro.com/custom_content/docs/manuals/C-10792 Instruction Mini Owners Manual.pdf
Click pics below to Enlarge:
  • Some small Questions about an Enviro Mini?
The door handle can be removed the bracket is made to put it in if you choose to remove it
Thanks
Any more answers? What is that hole for?
