traviswalken said:
I recently bought a home with a fireplace and plan to purchase a Hampton wood insert asap.
I have owned a wood stove in the past but probably didn't use it properly. I have a few wood related question that I was hoping to help with:
1. Eventually, I will cut my own wood. However, to get me going this season, I plan to purchase wood. Any tips on getting a good deal on wood would be appreciated. How can a make sure my wood is really ready for burning?
2. I plan to store my wood in my garage. Are there any problems with this?
3. A good link to a wood burning 101 type article would be greatly appreciated as well.
Thanks in advance for your help!
Welcome to the forum Travis. Please do not hesitate to continue with questions as they come to you as there is much knowledge here on hearth.com.
The number one problem with people when they start to burn wood is that they usually put in much time and effort into the planning of the stove, hearth, chimney, etc. and then, only then, do they begin to think about the fuel supply. This will work if you are burning oil or gas as you can just call the supplier and have some delivered and it will be ready to burn. However, do not think for a moment that can be done when heating with wood.
The number two problem with new wood burners is that they will believe a wood seller when he says the wood is seasoned. I used to say 99% of the wood sellers do not know what seasoned wood is; now I believe it is closer to 99.9%
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
! Many just say it is seasoned because it sounds good and makes a sale for them. Many honestly do not know. One of the problems is that today's stoves burn a bit different from the stoves that were used 50 years ago. Another problem is that wood sellers just usually do not have room to store wood until it is dry and that would also mean handling the wood an extra time which would bite into the profits.
So, how can this be overcome? Not easily but hopefully you can get through the first year with minimal problems. The worst problems arise when the chimney starts to get a narrow opening because creosote is clogging it. Then the draft for the stove diminishes and suddenly that stove just won't heat worth a hoot. Or you may even begin to smell smoke and/or creosote and you wonder why. Another problems is simply getting the fire to start at all.
If you buy wood now, do it as soon as you possibly can. Do not store it in your garage. Pick a spot on your place where it will get the most wind. Also pick a sunny spot if at all possible. Wind is more important than sun but both are great. Re-split the wood if possible so you have small splits, which will dry faster. Lay something on the ground like landscape timbers or 4 x 4's or similar. Some even like old pallets. If you use landscape timbers or something similar, lay down two and then stack the wood on that.
When stacking that wood, do not try to stack it tightly to really make it look extremely neat. Remember that the wood needs air so stacking it loosely will help to dry it faster. I would not worry about covering the wood at all unless we have a really wet fall. They you would cover only the top of the wood pile; never cover the ends or sides of the stack. Also remember to stack the wood so the wind will hit the sides of the piles and stack in single rows. After you get 2-3 years ahead in wood then you can stack more rows together and even stack it tighter if you want.
Here is a picture to show how we stack our wood. This wood will stay in the stack for a couple more years.
You will notice we've stacked in rows of three. You can do that when your wood has the necessary time to dry but do not try that in your first year or two.
So what kind of wood should you buy? If the wood seller wants to sell you some oak (which is great fuel), do not buy that in your first year of burning. It simply takes oak too long to season properly. Some great wood for this year would be white ash as it does not have a high moisture content to start with and will dry fairly quickly. We one time had to burn green wood one winter and burned nothing but ash. We did not freeze but did have to clean our chimney 3 or 4 times. I am not familiar with some of the woods you have in your area so will not offer other suggestions on wood types except to say you want a hardwood.
Once again, please do not hesitate to bring all your questions here on hearth.com as many will give good answers. There might be a little difference of opinions on a few things but mostly we agree on the basics. There might even be a bit of ribbing on occasion but all in good fun.
Good luck to you.
