S
StihlHead
Guest
Anyone build/use a solar firewood drying kiln?
http://www.builditsolar.com/Projects/WoodDrying/wood_kiln.htm
Yes, I have mentioned it a few times and usually I am ignored or branded a heretic!
Forest Service Study:
http://www.fs.fed.us/pnw/pubs/pnw_rn450.pdf
"I don't make this stuff up, I just report it."
Gallagher
Two issues... one, they are 'drying' impossible to dry unsplit birch, and two they were testing in very high latitude Alaska. I realize that birch is one of the few firewoods available in Alaska, but if I leave birch here unsplit, it will rot before it dries out, regardless. So I do not think that is a good test for this type of solar kiln.
I would like to see results from lower latitudes using a different species and of properly ~split~ hardwood. Oak, Alder, Maple, something else. Then I would believe it, but until then my engineering background tells me that a warmer solar kiln will effectively dry wood faster than without one.
I also saw Gallagher film one of his movies in Sand City, CA... under a tarp, of course.
Over the years I have run across a few articles talking about speeding up the drying process with a kiln, plus Augie posted his before, what exactly are you looking for?Agreed. It is, so far, the only relevant study I've been able to find. My only thought on the subject is that the kiln must be somehow ventilated to remove the moisture while still holding the heat. One of the east coast, lots of oak people should do something similar. Anyone? Anyone?
I'm with ya man ,going to try it next summerYes, I have mentioned it a few times and usually I am ignored or branded a heretic!
I have used one successfully to season Oak from the mid 50's to just under 20 percent in 4 months.
Mine is much simpler, I use clear plastic and scrap wood to make a frame that is attached to the wood I am looking to season. Cost is about $20 for 2 cord(plastic cost) but I can use the plastic a few times I think. I am getting ready to cover the second two cords for next year. I think with this method I will not have to keep more than one year ahead at any time.
Sounds like a good idea thereI am doing a test this season. I moved my stacking area two years ago with my usual top covering. Seems the ground under the new area stays wet. When I moved the stuff into the shed in April like I always do a lot of that oak was wet.
I had just put a solar powered gable fan in the attic replacing the AC powered one that crapped out. In June I had the roof replaced and ridge vent installed so I took the solar attic fan out of the attic and installed it in the front of the woodshed and when the sun is out it blows into the shed. Been doing it all summer.
Hope that does drying stuff.
I have posted a white paper from Cornell a few times that contradicts the Forest Survey. It is what I used to base mine off of. studyhttps://www.google.com/url?ttp://www2.dnr.cornell.edu/ext/info/pubs/Harvesting/CC Accelerated Seasoning of Firewood.pdf
For the East Coast , I am thinking your freezing temperatures over multiple days and weeks may hinder the progress of your wood drying. I may have mentioned before, I oak rounds up to 2 ft. across that are seasoned in 1 year. I collected them sometime earlier this year. If I remember right, this stack of oak was cut last September '12. I just split it yesterday, Harbor Freight Moisture Meter says 10%-15% in the center. It is Blue Oak. As long as we're looking for experiment ideas, I would try digging a compost pit to generate heat, build the greenhouse to include the wood stack and compost pit, the wood will not freeze and maybe it will season a lot faster.There was a problem with that link, but I found it.
http://www2.dnr.cornell.edu/ext/info/pubs/Harvesting/CC Accelerated Seasoning of Firewood.pdf
Good info, and pertinent to the parts of the country where humidity is high(er) and hardwoods season slowly.
I wouldn't say that it contradicts the other study, since the wood was a different species and was split. These kind of details can result in large differences.
It is somewhat limited in scope, did not have a control group and provded no actual data, but is still very encouraging. Much more promising than the Alaska study. I would like to see someone take a batch of green oak (both split and small diameter unsplit rounds), divide it into 2 stacks side by side and construct a solar kiln over one. Then take moisture measurements over the course of a summer. Based on this white paper, I suspect it would be beneficial for people with limited storage space to build solar kilns.
Break out the plans manNo, but I've thought about building one for several years.
I've got plans saved.
Augie, I think you are difinitely on to something that works. Try it one more time, but leave one stack outside the kiln as a comparison to the kiln enclosed stack. Then report the results. I too want to dry my wood without having to keep three years around, if possible. The 5+ cord that I have now are topping out much of my usable space. I need about 9 cord to make the three year goal, and if I could cute that number back by using a kiln, then I would be happy.Yes, I have mentioned it a few times and usually I am ignored or branded a heretic!
Wood will dry even in freezing temps. I have studied all kinds of effects of snow and ice melt in avalanche training for the ski patrol. Evisceration happens (water vapor forming directly from ice and snow) below freezing, similar to evaporation happening (water vapor forming from water) above freezing.
