soffit/overhang under side flashing?
Kosmonauts
220
Pennsylvania
Hello,
About to finish up my installation with the duraplus triple wall chimney pipe and have run into a little bit of a pickle. I am going through my soffit/overhang and basically just want a piece of flashing on the under side of the overhang where the pipe starts to go through.
I saw on duravents website that they have a "soffit overhang trim plate," however, I cannot seem to find that particular piece anywhere.
The outer diameter of the entire pipe is 10", and even if I could find a piece of flashing with a 10" hole in the middle that would work just fine. Anyone have this sort of issue before? Any advice is appreciate thanks a ton you guys!
Joe
Just get a piece of aluminum flashing or galvanized sheet metal and cut your hole in it. Then paint to match whatever your soffit is.
