OK, looking for ideas here. Finally got cold enough to use the stove this year and Ive noticed some smoky smell in the house - this morning after a low overnight burn and this afternoon after the morning load burned down to coals.
We also smelled some smokiness a couple weeks ago from the stove when it wasn't even burning on on a windy day.
I checked and all the gaskets, etc are tight and the stove does not display any symptoms of a leak.
I used to be of the "you cant ever make an antique house too tight" thinking but with all the insulating and caulking Ive done I wonder if it is possible the place is tight enough that the stovepipe has become the path of least resistance and its back drawing a bit after the pipe cools down?
Ideally we would get a blower door test to validate if we need make up air, unfortunately when I had an energy audit for the insulation work they refused to do the test because the house used to have asbestos wrapped pipes (long since removed)... too afraid of liability.
For now Ive got a basement window cracked, and will see if that resolves things. If it does I guess that confirms I need ventilation.
I'm looking for opinions-
#1 - Any other ideas what could cause smoky smells?
#2 If the basement window test validates its a venting idea - any suggestions to remedy this? (Adding an OAK would mean running a duct across the living room floor -non starter. Installing a makeup ventilation duct in the basement not so easy either due to the 7 in thick sill beams I'd have to bore though.)
