I recently purchased a home in upstate NY built around 1975 that has a large masonry fireplace. I had the chimney inspected shortly after closing - the inspector swept the chimney and confirmed that everything looked good.
Since then, I've had about 5 fires with kiln-dried hardwood and each time the house smells very smoky during and after the fire. One time it was so bad that the air was visibly smoky and our smoke alarms went off. After the first smoky fire, I read up and have done all these things:
- made sure the flue was wide open before starting the fire
- pre-heated the open flue with a piece of rolled up newspaper
- cracked a window in the room
- used the 'top down' method of burning
- kept wood toward back of the fireplace
- kept glass doors shut for most of the fire (if I open them, the smoke gets much worse)
I called our inspector back to ask if he had any tips, but he didn't say anything I hadn't already tried.
There are two things that make me suspicious about the fireplace: 1. it has some kind of u-shaped heat transfer thing inside of it that partially obstructs the flue, 2. there is a small gap between the fireplace face and brick near the top (see pics). The inspector said that if the chimney were drafting properly neither of these things should be an issue.
Wondering if anyone has thoughts / suggestions about how I should try to debug this situation.
![IMG_4002.jpg IMG_4002.jpg](https://www.hearth.com/talk/data/attachments/273/273997-584ce6bdb2e6b0bce8785f34ca719c02.jpg)
![IMG_4011.jpg IMG_4011.jpg](https://www.hearth.com/talk/data/attachments/273/273994-097d19177af511825f1d64ec80b4bbc4.jpg)
![IMG_4009.jpg IMG_4009.jpg](https://www.hearth.com/talk/data/attachments/273/273995-5485cf4bff54e568ba689364a1b19868.jpg)
![IMG_4012.jpg IMG_4012.jpg](https://www.hearth.com/talk/data/attachments/273/273996-4051b4dfe311df285480dcb95534d0b7.jpg)
