I hope this has not been asked before, but I am at a loss here.
I have an older Timberline wood stove. Don't know the exact age, but my parents put it in long time ago. Think it has to be a good 30 years old. And still in great shape.
Anyways, it's always been a really good stove. With good wood, it can heat you out the house.We've burned a ton of wood in this over the years, the set up has always worked very well.But the last week or so, it's like there is no draft. Even with the flue open all the way, you can't keep the door open more than a 1/2", or smoke comes out.
I thought the chimney might need cleaning. My mom said a furnace guy took the elbow off a few years back and said it looked okay.
So, the last two days I've taken all pipe off from the stove to where it goes into the ceiling, in the basement, into what I think is a double wall SS chimney unit setup, no brick or masonry. The chimney had some soot, but did not look terrible. There was also some stuff in the pipes I took out.
I bought a chimney brush and cleaned it up all the way to the chimney cap. I also replaced all the pipe from the stove to the main chimney with brand new stuff. Cleaned out the stove as well. I did not inspect the chimney to carefully, from what I could see, but it looked okay, from what I could see, and I remember seeing light at the top by the cap. Nothing to obstruct that I can see.
So, we try a little test fire and sure enough, smoke comes out the door and even at a joint in the new pipe I put in.
It's like it's not getting any draft. But this stove has always had a great draft, long as I can remember, you could open the door a few inches and see the fire glowing, it could easily see it was getting a great draft.
What could be wrong? Nothing has changed. It was smoking before I put in the new pipe, so it was an existing issue. Nothing else has been done on it and nothing really new in the house. I've read online that it might be a leak in the chimney lining?
Just don't get it. We have a bedroom in the basement where the stove is, so a fire would really be nice, it gets a little chilly down here. Not to mention we hate to buy more gas![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Any thoughts? Anything would be greatly appreciated! Sorry for the long post, just trying to be as detailed as possible.
