I recently moved into a house that has a Treemont TAC-260 wood stove insert. I had the chimney and fireplace cleaned and I tried to use the stove. I opened the primary and secondary dampers as stated in the owners manual, but the room keeps filling up with smoke instead of going up the chimney. What is the problem? I have no clue this is my first time using a wood stove. The smoke is coming through the holes where the primary damper is located directly above the loading door. Also the owners manual says "after the fire is ignited and burning briskly to close the secondary (back bypass) damper. HELP![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
:grrr:
