Hi all!
I know this has already been touched on in many different threads, but I’ve read through a lot and am still having an issue:
This is our third year burning with our stove. Never had any problem with smoke leaking into the house until the other day. Basically my husband started a fire (cold start) in the same way he usually does. After a minute or so, the entire room was filled with smoke. It was leaking in from where the pipe connects to the ceiling box thing (attached pictures). He smothered it. We cleared the room. When we went to restart it again, everything was fine, no more smoke, etc.
We thought it was a fluke, but it did the same thing yesterday, again starting from cold. We smothered it, then restarted it again and everything was fine. Until about an hour later, smoke started coming in from that same spot.
Other details that might be important:
-we have a mobile home, no two stories
-no vents or fans or dryers were on anywhere in the house
-it has a fresh air intake
-our house is NOT well sealed
-it happened with windows open or closed
-chimney pipes go straight up and out. No bends/curves/etc. (probably 10 ft total)
-inside it’s double wall pipes
We’ve already swept once this season, so it shouldn’t be that much buildup, although he’s going to sweep again tomorrow to just be sure
It was cold outside both times. The first time was in the 20s
The chimney cap is not clogged
The *only* thing I can think is that we have had to use some subpar wood recently. Circumstances happened and we no longer have our properly stored, well-seasoned oak, so we started resorting to improperly stored, maybe seasoned wood that’s a mix of soft and hard woods. Could that really be the issue?
I’ve attached pictures of our inside setup and a closeup of the joint where the smoke was leaking in at in case that helps.
Any ideas would be greatly appreciated! Thank you all!
![Smoke Starts Leaking Into Room All of a Sudden? Smoke Starts Leaking Into Room All of a Sudden?](https://www.hearth.com/talk/data/attachments/322/322267-df3115d93226b3c6da8c8e86d43eef02.jpg)
![Smoke Starts Leaking Into Room All of a Sudden? Smoke Starts Leaking Into Room All of a Sudden?](https://www.hearth.com/talk/data/attachments/322/322266-31732379e5c28ec511f4e3e495505462.jpg)
