I check the interior immediately after splitting at outdoor temperature. All of my wood is 19% MC or less, probably averages 15%. It's a 2 story house, so the flue is maybe 20 feet tall.How do you check with the moisture meter?
Do you bring in a big split, let it come to room temperature in 24 hrs, the resplit it and measure on the freshly exposed surface - so you measure the moisture content of the interior?
How long has the wood been (split and) stacked off the ground and top covered?
How tall is your flue?
I do push the pins in deep, but checking at room temperature seems a bit much. If I add 3 to my average reading of 15%, I'm still considered dry enough to burn. Some of what I've burned even reads EMC.Unless someone says i push the pins in as deep as they will go without breaking them, and into a fresh room temp split, i add 3 to 5 to their readings.
At night I choke the stove all the way down so it burns as slow as possible. But I've always done that.Are you choking the stove down too much?
Somehow you're producing too much smoke particles.
If your wood is dry, you're not burning properly.
But: Check for a leak in the stove pipe connections; adding cold air there kills draft and can result in sufficient decrease in temperature to lead to condensation.
Yeah probably got some wetter than normal wood, also the last 2 years were very warm so mostly everyone burned less than normal and definitely less than this year so far.Yeah but he says he's always dialed down this far, and only now is it problematic.
Unless he got a wet few loads that started a spiral I don't know...
Is your wood tarped or in a shed?
There are 2 perforated tubes in the upper part of the stove, and their holes look clear.Is your secondary tube air flow still clear?
The problem with more air is risk of overfiring. It gets over 500 degrees fully choked.i'd still be concerned with fully choking the stove at night. Maybe try giving it a bit more air.
Shed.Is your wood tarped or in a shed?
Definitely not! Could a strange species cause a problem? I've been burning a pale, light mystery species that looks and feels almost like balsa.Yeah probably got some wetter than normal wood
I don't know enough about the air paths in your stove, but you may have to ensure the tubes running towards those tubes are clear. (spider nests?)There are 2 perforated tubes in the upper part of the stove, and their holes look clear.
Shed.
My owner's manual says 600 is the maximum permissible continuous operating temperature. I don't want to flirt with a limit while I'm asleep.Folks cruise at 650.
Yes, I regard those flames as burning the smoke rather than the wood.Do you see those flames? Secondary flames?
2 years.How many years was your wood stacked in the shed?
Absolutely! Messes with the air flow.There is a badly warped piece of steel at the top front of the stove. Could that be causing a problem?
I understand, and am a bit surprised.My owner's manual says 600 is the maximum permissible continuous operating temperature. I don't want to flirt with a limit while I'm asleep.
That is correct.Yes, I regard those flames as burning the smoke rather than the wood.
That is good for most, and may not be enough for oak.2 years.
Maybe. But now we're going to have someone with knowledge of this particular model...There is a badly warped piece of steel at the top front of the stove. Could that be causing a problem?
Warped thing ...I understand, and am a bit surprised.
That is correct.
Do add a pic of this.wsroed thing.
