New Harman Accentra Pellet stove installed. Direct Vent - Stove adaptor to clean out T, to 90 degree elbow, straigt out through wall 4' to the great outdoors. (Every joint, including the 90 is sealed with high temp clear silicone.)
Smell of smoke in the house when the stove is lit. Visually there is no smoke (with the service covers removed on the back of the stove) anywhere inside our around the back of the stove. There is no leak from any of the stove pipes. There is an odor in the room the entire time the stove is running.
In the top right hand corner of the stove, where the top of the stove meets the back and right side wall, the stove has a whistle just under the stove top. You can put your finger under the stove top and stop the whistle. In further testing the whistle is caused by postive pressure (exhausting away from the stove) when tested with a blown out match. You can detect a smoke smell from the corner where the whistle is coming from. You can not see smoke anywhere though.
Can anyone explain why this leak would be "normal" or acceptable? The dealer says no problem, and that the leak is not coming from that whistle sound. I have looked at 2 other stoves (identical) and can not detect so much as a whisp of smoke when they are running. No whistle, no problems.
Paul
Paul
