Hello all.
I just had a brand new Enerzone 1.6 wood stove installed in my basement rec room. The stove is vented through double wall pipe into a clay liner (6x6). The chimney was swept as part of the installation. The house is a 1970s build.
I noticed a couple of days after having a fire there was a strong smoke smell in the room. I have the main air control closed (although there is a dime sized safety hole). I also noticed a strong draft of cold air blowing out from the secondary air intake when the stove is not in use. My stove does not have a damper on this secondary air (which i guess is typical of EPA stoves?). Maybe this is normal but its pretty unpleasant. I've heard some people will install stove pipe dampers or block the secondary air with magnet or something. Any suggestions?
thanks!
thanks!
