I have found a little strip of grey asbestos-type material on the floor, presumably from the glass door. I thought there are gaps along the top to allow air to pass through. Unfortunately, I can’t figure out what the configuration is for the glass in the top channel.
I have been getting smoke smell at startup.
The door seal is perfect, because I can see the change from grey to white.
I do annual stove removal, scrape, scrub, power brush, replace/repair seals as needed. I refurbish and lube the motors, clean and reseal vent pipe. So, I think I have eliminated many of the other variables.
QuadraFire CB1200
Hot Shots softwood 100% Oregon pellets
QuadraFire CB1200
