Hi - new to the forum here, hoping you might be able to help.
I have a problem with smoke smell coming into the home for several days after burning a wood fire in our fireplace.
I have an open masonry fireplace (with glass doors), terracotta flue tiles which are 13" square.
There is no outdoor air kit coming to the firebox or anywhere into the home.
Chimney is exterior to the home, one story, and does extend 3' above highest roof penetration (probably 5'), and roof peak is 12' away from top of chimney (horizontal), but the roof peak is about even with the top of the chimney.
Total height is 30' from ground to top of chimney
Home is pretty tight w/ new vinyl windows.
The smoke chamber transition to the flue looks kind of rough (not a super easy/smooth flow for the smoke to get into the flue)
Phase 1: when we bought the house (2012) the chimney was inspected and it was found that the flue tiles did not extend past the roofline so there were a few feet where the flue tiles had stopped at the roofline, and smoke would have been expelled into the masonry/chimney, then out through the top square flue tile in the chimney crown (
). I burned a couple fires, but draft was terrible even with all appliances off and window open, the fireplace would smoke back into the room. I stopped burning after maybe 3-4 fires, and gave up until I could have it repaired. I got quotes from reputable repair co's and had it professionally rebuilt from the roofline up with terracotta flue tiles extending to the top and totally re-pointed top to bottom to boot.
I added a lyemance top damper and cap because the old original flue damper was rusted out (I removed the throat damper door, but the frame of the throat damper remains).
I've tried sealing it as tight as can be (proper heat resistant sealant from a chimney supply co on all cracks in the firebox/external joints where the door frames meet masonry.)
I did have the chimney professionally swept in between fire #2-3 but to no avail.
Phase 2 (currently): I went to prefab logs and those seem to go ok - only maybe 4 or 5 of them after the repair, not as bad of a smell afterward. I built one all-wood fire on super bowl sunday (2/5) and am still getting the smoke smell. The wood has been seasoned for at least 1 year, but I did notice one piece was wetter than I thought/steaming. I am having to keep a window next to fireplace cracked 24/7 and running the air purifier, top damper was left open overnight and closed the next day after fire. Doors and air control vent underneath doors are closed - I even rigged a magnetic strip to cover the vent holes after fire was out. Ashes/one small piece of remaining burnt wood were removed in a non-combustible container on Tuesday, but I'm still really getting the smell. I looked at the cap this AM, it's not clogged with ash or anything, and the holes are pretty massive anyway.
Naturally, the companies out here are happy to give me a quote for a fireplace insert but I'd like to leave no stone unturned before having an insert or new prefab fireplace installed with the proper steel (?) liner to the top. One reputable company also provided an option of (if I understood) parging the smoke chamber to transition to a steel liner flue without using a fireplace insert. Mostly, i want to understand what the heck is going on.
Help please? I can add pics if it'll help.
Specs:
Fireplace opening has a rounded top: 35.25" wide x 16"H at end and 19.5" H at center
Throat opening is made by the original steel throat damper frame, it's a trapezoid opening and is 30"w at back, 28"w at front and 5.25" deep - it feels really narrow to my eye, but I don't know.
Thank you very much.
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Specs:
