Ok so I'm trying to track down the mystery smell on my insert.
If the insert was leaking smoke/exhaust (say from a leaking joint - it's a gasketed cast iron insert) then a carbon monoxide detector should show at least trace levels, right? My detector would show if it was at 10ppm or more but it always reads at zero, even when I check the "peak" button which shows the highest reading since it was last reset.
I'm hoping I can rule out leaking smoke with a 0ppm reading in my CO detector.
