I'm assuming a carbon monoxide detector is a good idea after installing a pellet stove? Or would a smoke alarm be good enough? Not sure how pellet stoves are regarding carbon monoxide. Suggestions?
I have invested in both!! I'll be sleeping better.ylomnstr said:I'm assuming a carbon monoxide detector is a good idea after installing a pellet stove? Or would a smoke alarm be good enough? Not sure how pellet stoves are regarding carbon monoxide. Suggestions?
cncpro said:....it is special in that it is wirelessly linked to another brand new unit in my bedroom. The end result is that if I get a smoke / fire problem with the stove I will be awoken immediately by the unit right over my bed.
stoveguy2esw said:ylomnstr said:I'm assuming a carbon monoxide detector is a good idea after installing a pellet stove? Or would a smoke alarm be good enough? Not sure how pellet stoves are regarding carbon monoxide. Suggestions?
wood stoves, coal stoves,pellet stoves , gas stoves , oil stoves all have one thing in common... combustion. this creates CO even if visible smoke isnt there. virtually all stoves of any type will not release CO or smoke into a home under normal circumstances. smoke and co detectors are for "abnormal circumstances"
bottom line...
if it makes a fire, and its in your home i dont care what it burns or who made it, you GOTTA have em smoke as well as CO. ive learned that sometimes smoke detectors may not go off even in a smoke event with a heating appliance even an electric heater, adding CO detectors gives an added level of security. my family would not be sleeping in a home that doesnt have them both in it. bottom line , if you aint got em yet , be at the door of the nearest store that sells em when it opens . sorry if i came on a bit strong , but im a bit anal about safety. numerous lives are saved by these devices every year, and they arent expensive, protect your family , install and test regularly the life they save may be you or your family.
macman said:cncpro said:....it is special in that it is wirelessly linked to another brand new unit in my bedroom. The end result is that if I get a smoke / fire problem with the stove I will be awoken immediately by the unit right over my bed.
Is that the First Alert OneLink units? I have 4 of them in my home....they work great! This one does smoke and co2 at the same time.
Both. But while some of the combo units are nice, you really want them split. A smoke alarm is good when mounted high on the wall or ceiling 'cause smoke rises. A CO detector is better located low because CO is heavier than air and tends to sink. Kidde makes a good CO unit that plugs into any wall outlet and because wall outlets tend to be located low, it's a perfect location. At least have one of them in the room the stove is in. I have a nice Nighthawk that cost about $40 with an LED CO sensing display to let me know just how much CO is in the air - it's comforting to see that red 0 down there.ylomnstr said:I'm assuming a carbon monoxide detector is a good idea after installing a pellet stove? Or would a smoke alarm be good enough? Not sure how pellet stoves are regarding carbon monoxide. Suggestions?
billb3 said:I use living plants for CO2 detectors.
If they die I make a point of breathing again.
orangecrushcj7 said:billb3 said:I use living plants for CO2 detectors.
CO2 is carbon dioxide. carbon monoxide (CO) is the poisonous gas. Plants won't react to CO the same way they do with lack of CO2
I have 2 Kidde nighthawks, one on each level. $35 each at BJ's. They have realtime digital readouts, and you can check the peak levels. I have never even had 1ppm at either location with the pellet stoves running.
hossthehermit said:Gotta say, I'm not a big fan of the lithium batteries in these. IMO, you're a lot better off having to change batts twice a year.....
