Hey folks. We moved into a house with a Jotul Kennebec c450 insert. It looks great and I feel like we should love it but I just haven't been able to figure out how to use it without smoking out the house and my wife is ready to rip it out and replace it with gas logs. My 2 year old woke up with a dry cough this morning I feel like it might be harmful to our health. I feel like I've gotten a bit better at it with every time I've used it but my entire 2200 sq ft house strongly smells like a camp fire and I am not sure we'll be about to get the smell out of our couches, rugs, bedding, etc. HELP.
Here's my setup as best I can describe it: I have an external chimney with a liner and cap and the chimney is roughly 20' tall?
Here's my current process:
1. clean out the ashes
2. lay 2 logs flat on the bottom
3. place some kindling on top of the logs
4. place 3 firestarter squares on top and light them
5. use a bellows tube (basically a long metal straw) to keep the fire going
questions/concerns:
1. I always leave the lever to the right. When a fire is out should I move the lever to the left (closed) so as to avoid the insert getting too cold?
2. Am I smoking out because I'm not properly warming the flue so as to reverse the air flow? If so, what's the best way to do that? I tried this most recent time to light some crumpled newspaper on fire to warm up the flue but I don't think it worked - perhaps it wasn't enough heat for a long enough time or perhaps I wasn't holding the newspaper ball in the right location inside the insert?
3. When I turn the fan on high lots of ash debris blows out above the insert so I can only set the fan to low so I feel like I'm losing out on a lot of potential heat movement. If I look in the space above the insert where I think I see the flue pipe I do see a pile of ash. What does that mean - why would there be ash there?
4. Once I get a fire going for an hour or two should I move the air lever or should I leave it all the way to the right?
5. I've seen videos on Youtube where they simply load up the insert/stove with wood, kindling, and some sort of starter square or newspaper, light it, close it, and poof they have a fire. If I do the same the fire dies instantly and smoke comes pouring out of the cracks around the doors so I have to keep the doors open and constantly tend it for a the first 20-30mins to make sure the fire has established itself.
6. I cleaned off the glass when we moved in in hopes that we'd be able to see the beautiful flames of our fire but after a half dozen uses the glass it black again and you can barely see the fire unless it's raging. Is that normal? If not, what does that indicate?
Sorry for all the info, but hopefully it helps me diagnose what the heck I'm doing wrong or if there's perhaps something wrong with my insert setup. I'd love to love this thing but after only a half dozen fires I'm pretty over it. THANKS![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
questions/concerns:
