- May 16, 2007
- 59
Hi All,
A friend has an LP gas fired fireplace - manufactured zero clearance design. I am not sure how this differs from a "zero clearance fireplace". I notice that some of the smaller fireplace inserts can be fit into zero clearance fireplaces. Would this LP fired zero clearance also be considered a "zero clearance fireplace". What are his options? He is thinking about going to a pellet stove because the flue requirements are less stringent. He has 6 or 7 acres that is wooded and has a plentiful supply of wood, but thinks pellets would be cleaner to handle and the heat source will be easier to modulate via thermostatic control, etc.
The smaller pacific energy insert looked good to me, also the smaller jotul insert - what would it take to mount one of these in the space?
The home is 2000 square feet or so - very well insulated newer construction. 2 stories. Climate is moderate - located near bremerton, washington.
He needs to get some supplemental/primary wood fired heat. He is remotely located and is currently heating his home with LP gas and getting killed financially.
jeff
jeff
