Hi Everyone
I have a small 24'x24' cabin with a small up stairs & I'm having a problem with trying to heat this building.I tried a Hearthstone Homestead p& the best I could get out of this stove was about 64 degrees & that was when it was 35 degrees out side.
Now this cabin has house wrap on the out side & 6" studed walls with the insulation to go with it.The chimney is stright through the ceiling & through the roof.The chimney is tripple wall the down to double wall in the living room & at the stove a short single wall with a damper this pipe is 6" SS .
I have sold the soapstone & now have tried a coal stove it works a little better but not much the best it did was 66 degrees & about 59 degrees up stairs.
Now my brother in law has one of those low cost $99.00 wood stoves from the tractor store he loads it up & in about 45 minutes he said it was about 50 degrees with in 2 hours he is taking his sweat shirt off.This shed has no insulation
What am I doing wrong.
Thank you
dgf65
Thank you
dgf65
!! I've burned 12 year old wood and for sure it was dry, but too dry? Methinks the problem was something else. btw, our soapstone burns dry wood very well indeed!
