This is a survey for those with small fireboxes and their reloading techniques. How much wood do you put in and how do you work the air? How long does it take to get to temp and what temp is that?
I have a Vogelzang Colonial and it has a firebox around 1.7. I can fit about 3 medium splits in my box on a reload. I have found the opposite works for me on getting my stove up to temp. The faster I can shut down the air the faster the stove will get to temp. I normally will crack the door ( depending on coal bed ) to get a flame going. Once the wood is lit which is fast, I have the air open to halfway. The wood takes about 10 mins to get burning well and then I shut the air down to closed or almost closed. Once I shut down the air, the stove goes from 300 to 450 in about 20 minutes. The flames do die down after I close the air but as the temps rise the flames take off. On a very hot bed of coals, I can put wood on and leave the air almost closed from the beginning. As the wood starts to coal, I open up the air to half way to maintain at least 400 degrees. When the temps start to die off more, I open the air all the way. This keeps the stove up to temp, the coals nice and hot for the next load, and cleans off the glass.
