Hi,
I just picked up a Lawnboy 2 cycle mower model 10590. It is a little strange to me. It has a gas tank and a 2-cycle oil tank. It mixes the oil with the gas as it runs. Anyway, it had been stored for about 4 years with no gas in it, but had 2-cycle oil in it. I first tried to start it with fresh gas but no go. I then took the carb off and it was real bad. The choke and the throttle 'butterflies' were stuck. I managed to get them free and cleaned all of the port holes and put it back together. It now starts and will throttle up nicely but when running it a full throttle it suddenly dies. If I kind of violently bang the mower up and down it will start up, but won't stay running at high throttle. When it dies, it just cuts out immediately.
It's too late to try it now, but the only things I have read are:
1. it could be the vent on the gas cap is plugged so the tank is not venting.
-- I would have thought that this would cause the engine to sputter then die, not just cut right out.
2. It is a mulching mower and rear bagger, I have the mulching plug in but not the bag. The bag is at my mother-in-law's house (no pun intended).
-- does the bag need to be on even when mulching. I found a manual on line and it talks about some shut-off for the bagger. I am able to start the mower without
any bag on it, I just can't keep it running.
Any help would be appreciated. I need this mower for about 100 sq ft and don't want to buy new if I can get this one working.
Thanks![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks
