Hi,
I have a mantis tiller (2 cycle) that I left the gas in over the winter. I had a hard time starting it and once I did, it was tough to keep running. I managed to get it to till 1 of my 6 raised bed gardens but it was tough. I did some reading here, in the mantis manual and on other web sites and this is what I did:
Emptied the gas
bought new air filter, carburetor diaphragms, and spark plug, and fuel filter
took the carb off and cleaned it using carburetor cleaner (The parts place said the carb was in good shape and not really dirty or gummed up)
put carb back together with new parts
checked the anti-spark screen and it had no crud on it.
Took the muffler off and no carbon build up
bought new gas and mixed in stabilizer and 2-cycle oil
Tried my best to adjust the carb low and high. On the mantix, there are stops on the low and high so you only have minimal adjustments. Maybe only 1/2 a turn on each. The Mantis manual said to turn the high all the way counter clockwise and put the low 1/2 way between the 2 stops.
After all of this, I got it to start and run for a while (2 - 3 minutes). I then squeezed the throttle and it would bog down. The manual said if that happens to turn the low adjustment counter clockwise. I did this in steps (again, the stops don't allow this to move that much) until it was all the way to the counterclockwise stop. It still bogs down when giving it throttle. I managed to till 1 more garden, but if I stopped while tilling I would have to remove the tiller from the dirt and rev it while it was out of the soil. Once going again, I could manage to keep it going. It did till, but with limited power.
I was guessing that I needed to somehow remove the stops so I could adjust the low a little more, but wanted to see if anyone here had any other thoughts. I figured it is just a 2 cycle engine so it should not be that different than a chainsaw.
Any help would be appreciated.
Thanks![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Emptied the gas
Thanks
