Hello all, just purchased a home with a wood burning fireplace in the living room. After having it swept/inspected (level 1) I come to find out that the stove is a slammer install. I had never heard that term before so after reading as many slammer threads on this website as I could find, I'm all caught up on what they are and how dangerous they are. The inspection found spauling flue tiles and missing mortar in joints. So, we can't use the stove. Which absolutely sucks because I love the look of the stove and it works great. I had to burn fires for a few weeks after the initial inspection attempt due to so much creosote build-up, they couldn't break it up enough. I had to spray the wood and firebox/stove outlet with a solution to help break down the creosote and burn fires. Anyways, I received a quote to fix from the same place that inspected the chimney and I have some questions that I'm hoping ya'll could shed some light on.
First, a little more information:
- Derco Grizzly Wood Stove
- FPI-2
- 6/5/1981
- Flue Length - 12' (straight shot and taken from inspection report)
- Flue Size - 16" x 12" (taken from inspection report)
Question 1 - Both options for stove replacement include removing the existing terra cotta flue tiles. My question is, would this be necessary if they are going to be putting in a pre-insulated 6" SS chimney liner? When I was up on the roof (flat roof) with the chimney sweep and he was showing me the missing mortar on the camera, he didn't say that flue tiles were in that bad of shape that they would need to come out. And if the flue size is 16" x 12" I can't see why they would need to be removed to accommodate the new pre-insulated flue liner.
Questions 2 - Both options for stove replacement are for a wood-burning insert. But with three sides of the fireplace being open, an insert isn't going to work right? It would have to be a free-standing wood stove like what is already there?
In my last house I installed a new wood stove/stove pipe/through the wall kit and new chimney pipe in my office so I have some experience with this. But this is a bit different obviously. I would feel comfortable doing this work myself as I have read plenty of threads, watched plenty of videos and consider myself somewhat handy. But I want to make sure I'm being shortsighted here.
As you can see from the pics I don't have access to the damper/inside of chimney because it is blocked off so not sure what is going on in there.
I know that the current stove is old and not efficient, but dang it, I'd love to keep using it. We only use this for "ambiance" and not heating the house. Current stove outlet is 8".
Anyways, any advice would be great and very much appreciated. Thanks!
![[Hearth.com] Slammer Replacement Advice [Hearth.com] Slammer Replacement Advice](https://www.hearth.com/talk/data/attachments/325/325008-6f68d0d1a6f25f44c7f7d8f408d293da.jpg?hash=NPiovjWloW)
![[Hearth.com] Slammer Replacement Advice [Hearth.com] Slammer Replacement Advice](https://www.hearth.com/talk/data/attachments/325/325009-9b0d7d735d01fd5282208b5217027c2f.jpg?hash=P_XnOU4kot)
![[Hearth.com] Slammer Replacement Advice [Hearth.com] Slammer Replacement Advice](https://www.hearth.com/talk/data/attachments/325/325010-76c58bdf255a553c9a1e2f0acbfe84e8.jpg?hash=qPULqfhduu)
![[Hearth.com] Slammer Replacement Advice [Hearth.com] Slammer Replacement Advice](https://www.hearth.com/talk/data/attachments/325/325011-8771cb20b9526e29b3ab608aedd615d3.jpg?hash=Ub5lZwbxQn)
- FPI-2
- 6/5/1981
I guess my ignorance is showing a bit here with how dirty a chimney can be after a sweep. So, with it being an old stove, with an 8" outlet, would the best option still be to install a 6" insulated SS liner and then reduce from 8" to 6" to direct connect?
