I love cheap heat said:
If your board has a slide switch on the front for "thermostat mode" you are looking at the wrong instructions. You only need to hook up your remote receiver to the connectors on the back of the stove. If you do not have the slide switch, you still connect the receiver to the connectors on the back, but you also have to make sure the J9 jumper is enabled. Be careful, only place the jumper on the 2 pins associated with J9. If you place the jumper anywhere else your stove will not work
What`s all this talk of milivolt thermostats needed on a pellet stove? I`ve seen this brought up before.
The only use of a milivolt thermostat that I ever knew of was in specific gas furnaces where the pilot light heats a thermocouple that in turn generates a milivoltage to power the control circuit. Quite handy in a steam system (usually a conversion) and no power needed.
With 120v power on board the use of a milivolt (powerpile) sytem is unneccessary and redundant.
On my Harman all that`s needed is a typical generic 2 wire 12-24v thermostat.
But then again , I could be missing something. Pellet stoves in general are a bit new to me.
John
