aandabooks said:What are you running that you put skiptooth on?
gweldgen said:What is the advantage of the skip tooth chain? If I use one on my MS390 with 20" bar how much of a difference will I notice from the Chisel tooth (yellow) that I use now? Also -are they any more forgiving of dirty bark?
Bigg_Redd said:Anyone not using them?
Adios Pantalones said:They're also the way to go if producing lumber with a chainsaw- like with an Alaskan lumbermill.
Adios Pantalones said:There are cheaper attachments that can be used, but for a reasonable log you need a beast of a saw. I thought about it too.
:shut: :shut: :gulp:Adios Pantalones said:Wish I had payed attention- I saw a guy saw a really wide OSAGE into planks one time- must have been using a monster saw.
One monster saw indeed!Adios Pantalones said:Wish I had payed attention- I saw a guy saw a really wide OSAGE into planks one time- must have been using a monster saw.
Be a great guy to know! We have alot of it around here a 12 in trunk is no chump with a ported 460 and you are talking about ripping it!WOWAdios Pantalones said:Ya- it was a guy named Marty from TX that I met through bowmaking.
He was famous for doing things like building his own throat extender on a bandsaw, replacing the 1HP motor with a 5 HP, and resawing osage lumber (they have lots of osage in the DFW area evidently). Go big or go home redneck stuff- great guy, and a little nuts. Wouldn't be surprised if he's dead from a contraption coming apart on him by now.
ak said:i have a skip tooth on my stihl 036 with a 20" bar which has changed to a 360 and then a 361, i also have one on my husky pro saw with a 24" bar. both are around 60cc and both slice right through the wood i am cutting. skip tooth chains work well with softer woods like what i am used to here in fairbanks ak, like spruce, birch and douglas fir, but with hard woods it tends to bog the saws down so a regular chain might work better unless yo uhave a good saw. it does cut wood though, i would say twice as fast as regular chains.
north of 60 said:ak said:i have a skip tooth on my stihl 036 with a 20" bar which has changed to a 360 and then a 361, i also have one on my husky pro saw with a 24" bar. both are around 60cc and both slice right through the wood i am cutting. skip tooth chains work well with softer woods like what i am used to here in fairbanks ak, like spruce, birch and douglas fir, but with hard woods it tends to bog the saws down so a regular chain might work better unless yo uhave a good saw. it does cut wood though, i would say twice as fast as regular chains.
OK I must have it backwards. My idea of a skip chain was for underpowered saws to maintain their rpm to keep the saw in its power curve to do the job. If you ran both types of chains at the same RPM wouldnt the skip chain cut slower as it would be removing less wood per revolution. So if you have the power a normal chain should cut faster so long as the chains we have been talking about are both sharp. I would say a skip tooth would be required more for hardwoods and less on softwoods using
the same power plant. YES / NO :question:
