Billy123 said:Some folks really chop/split their wood thin, some don't.
Any advantage/disadvantage to split size?
I'm thinking with equal volume the large splits will burn longer due to decreased surface area exposed to the fire. Kinda like how a tray of ice cubes will freeze faster than the same volume of water in a single larger containerbasswidow said:The really big splits we call "nite nite logs", as they are perfect for the last long on top when we dial it down and turn if for the night. Yet a variety is best.
I would like to see an experiment to see if a firebox filled with the same volume of larger splits vs smaller splits burns any longer. The perception is - bigger splits burn longer, but as long as you are packing in the same volume - you should get the same output? Shouldn't it? Maybe it's just a visual perception.
chvymn99 said:I've questioned the size of my wood too, seeing all these big splits of wood. But after my first half year of running my stove. I figured out that with my small 16" entrance space and limited inside dimensions. A quantity of small chunks burn better than a few bigger chunks in my experience. So for this year, I got a lot more small chunks to go with. But I also watch the shape and configuration of the wood itself. I created a lot of square chunks for overnight burns, out of the center of the rounds.
jatoxico said:chvymn99 said:I've questioned the size of my wood too, seeing all these big splits of wood. But after my first half year of running my stove. I figured out that with my small 16" entrance space and limited inside dimensions. A quantity of small chunks burn better than a few bigger chunks in my experience. So for this year, I got a lot more small chunks to go with. But I also watch the shape and configuration of the wood itself. I created a lot of square chunks for overnight burns, out of the center of the rounds.
Don't beat yourself up, size prob doesn't matter :lol: .
JimboM said:Jay Shelton in his Solid Fuels Encyclopedia, figure 14-5, page 217: Ten percent increase in overall efficiency of an air tight stove using 15% moisture content wood burning 6.5 pound splits vs 1.6 pound splits. Makes sense to me as bigger wood burns at a slower rate.
chvymn99 said:jatoxico said:chvymn99 said:I've questioned the size of my wood too, seeing all these big splits of wood. But after my first half year of running my stove. I figured out that with my small 16" entrance space and limited inside dimensions. A quantity of small chunks burn better than a few bigger chunks in my experience. So for this year, I got a lot more small chunks to go with. But I also watch the shape and configuration of the wood itself. I created a lot of square chunks for overnight burns, out of the center of the rounds.
Take it to the gutter...
