Kudos to Slow1! I'm glad to hear that someone is using a moisture meter to identify when wood is well seasoned. That truly is the only way to be sure of the moisture content of wood when trying to rush the process. Of course, if you can wait two years...save the money you'd spend on the meter and buy more wood. (The wood should of course be split, stacked and covered properly)
I hear and read an awful lot about seasoning wood for proper burning and that is commendable. But something that is highly overlooked is style of wood burning. It really is a balancing act that can take a few years to get the hang of...if you pay attention to the flames.
Many of the comments made here are correct, but I feel that style is being overlooked.
Yes, Larger pieces burn well overnight, but take longer to dry. Smaller diameter pieces dry out quicker but burn faster and need more maintenance.
I think your flue temperature should be your guide.
Larger pieces that burn longer through the night have more of a tendency to smoulder. That's bad. It builds creosote even though the wood may be seasoned. Where there is smoke, there is creosote. Burning smaller pieces makes a hotter flame creating a hotter flue which reduces smoke and thus creosote buildup. Unfortunately it burns fast and does not last through the night.
For a mid size stove (circa. 70,000 Btu's)Keep your splits to a maximum of about 6" diameter. This size dries relatively quickly (in my region at least) burns well through the night leaving a nice bed of coals for an easy morning start. Most of my pieces are split to about 5" or less. I even split 2" diameter limbs on my Hydraulic splitter for quicker drying because bark slows down the drying process considerably.
Most of my splits are 3-5 inches in diameter and for an overnight burn I'll fill the stove with mostly 4-5 inch pieces...some 3's and 2's ..... get the flue temp up to 550 Degrees or so and close the air control slowly to about 60%. This creates a healthy sustaining fire that burns through the night.
If you don't get a good overnight burn with these sizes, you might be getting too much draft, your stove might need replacing to the more efficient EPA rated stoves, your gaskets might be worn or some other unforseen problem. Watch the temperature on your flue. That's a good indicator of what's going on inside.
One more thought, checking on the end grain of whole logs doesn't mean anything with regards to seasoning wood. I've seen checking on cut logs (12" in Dia.) after a couple of days of being freshly cut. Five years later, that same log unsplit, if it's stored outdoors, will still be too wet for burning! Cut it open and take a moisture meter reading. You'll be surprised at how wet it still is inside.
Ted
Burn Responsibly
www.woodhomeheating.com
