What would cause a shorter life span using a single wall black pipe insert instead of stainless if the top plate protects from elements.
burn it said:a ul approved insulation will not protect against chimney fire?
burn it said:If no block-off plate was put at damper opening, wouldn't that keep the flue dry and warm.
