Hello! I did a bit of searching, and couldn't find anything that quite answers my specific question. Hoping for a little bit of help, if possible.
![Single piece of Bluestone tread as hearth extension pad? Single piece of Bluestone tread as hearth extension pad?](https://www.hearth.com/talk/data/attachments/264/264795-8b5d173de0fb57423b29bdf0ea8f2d5b.jpg)
![Single piece of Bluestone tread as hearth extension pad? Single piece of Bluestone tread as hearth extension pad?](https://www.hearth.com/talk/data/attachments/264/264796-7551bc7bfe0107000d4cdf898b4c77da.jpg)
I have a Pacific Energy Neo 1.6 insert. Unfortunately, as you see in the pictures, a smart Aleck previous owner removed the heath extension entirely, and put laminate floor right up to the fireplace. Sine I got it the insert installed, I've just been using a generic hearth pad that the install company sold me. It's falling apart and I'm looking for something nicer and more permanent.
My plan is to drop a single, solid piece of bluestone in front of the stove. I'm just looking for the best way to install it. As you see in the second picture, once I pull up the laminate I'll have ~1.5" of clearance. Bluestone tread is 2", but I should still be able to swing it. When I drilled a hole through the floor, it looks like there is about an inch of "stuff" before getting to the crawlspace. It's either: A. An old hardwood floor on 1/2" plywood subfloor, B. just a really thick plywood subfloor, or C. Knowing my house, some crazy nonsense no one in their right mind would ever think of. Either way, I'll likely strip it down to the studs, this way I can add a little extra framing under where I'll put the stone, just to be safe.
Here's where I need some help. My plan is to put down 1/2" plywood on the framing, and then the stone on top of that. Should I use mortar in-between? Thinset? What kind, specifically? I'm just not sure. I see a lot of people put tar paper and lath, but this is when they are either tiling or placing multiple stones. This seems unnecessary for one giant, 150 lb+ stone. With that weight, do I even need mortar? (I'll at least put some between the new stone hearth extension and the existing hearth so embers can't get to the subfloor).
It just seems odd to me to put down tarpaper or some underlayment, and then glue/mortar this stone to the paper, not to the subfloor. Plus, as you can see, I don't have a whole lot of wiggle room between the framing and the bottom lip of the stove.
Sorry for the text block, just trying to give as much info as possible. Any help would be greatly appreciated!!
