Been lurking for a while gents and would just like to say--What a great site!!. I have just stumbled across and purchased a Simplex Boiler oil/wood combo unit. Model number OCF -225 I believe. It has a plate stating that it is rated for 280,000 BTU. Still has the oil assembly on it also. Planning on installing this in my garage and piping it into some thermal storage tanks in my basement. I have a few questions that maybe you can help with. First of all my home is a two story 2000 sq ft completely uninsulated home that has two zone base board hot water heat already installed but the natural gas fired boiler is trash. Like I could afford the bill anyways! I also have a full basement with a concrete floor. The home is in Michigan near lake Huron so we get a heck of a breeze all winter off the lake. Home was built in 1935. No insulation then??? Of course I will be insulating in the spring but right now I have no heat at all so that is the financial priority.
What size tubing should be used to adequately move enough heat from the boiler to the thermal storage tanks?
How many gals is considered adequate for thermal storage. I would like to fire this boiler once a day for 4-6 hours max. Just one burn after work in the evenings.
Has anyone ever used old fuel oil tanks for thermal storage? I can barely get one of those into my large basement.
Am I nuts for using a 280,000 BTU boiler and should I just stop now and get something smaller??
