Passing along an idea here in case it may help others-
It's time for me to get back in gear on completing my storage- my Econoburn 150 worked well intially without it, but I am looking forward to the increased convenience and flexibility (plus DHW) that storage will offer.
One of the things that slowed me down on finishing the storage and connecting it to the boiler was finding some non-ultra-pricey large diameter piping material (and connectors) to span the 18+/- feet from my boiler to storage-- but that would handle any foreseen temperatures without any risk of failing (either the tube or at any joints/ fittings. The thought of hundreds of gallons of near boiling water spilling around my basement for hours (if something failed) really was uninviting. I decided to plan to place the FlatPlate HX near the boiler, so that at least the main length of piping to and from the unpressurized storage would not need to include oxygen barrier, or be subjected to potential moderate/ high pressures- but that still left the temperature issue.
Even then, I was coming up stumped on what to use that would be about 1.25 net inside diameter, could handle 200 F with near zero risk of failure, and would not cost an arm and a leg (especially after figuring in end connectors and several turns' worth of fittings needed to get around obstacles)
Then... after looking into many things that weren't quite right (mill hose, CPVC schedule 80... solar-rated hoses), thought of silicone vehicle heater hose-- but... too expensive. Then-- onto eBay, where, at last, I found 75 feet of unused 7/8 inside diameter/ 1.25 outside diameter reinforced silicone food grade tubing -- rated at up to 400F, and 100+ PSI, for less $$ than I'd pay for two 10 FT lengths of 1.25 copper pipe.... I'll run two parallel sets of the 7/8 silicone in each direction (to and from) the tank to achieve approx the same flow as 1.25-- and the 7/8 inside diameter will allow use of the outside diameter of 3/4 copper as fittings (with outside clamps, doubled) at the tubing ends. Tubing has arrived- looks bomb-proof. Onward to ordering some other parts and moving forward...!
