![Sierra Classic 2000 Hearthstove - Flue Connection Sierra Classic 2000 Hearthstove - Flue Connection](https://www.hearth.com/talk/data/attachments/231/231458-b3ce2369b238624a0f2bd26db312ffc9.jpg)
![Sierra Classic 2000 Hearthstove - Flue Connection Sierra Classic 2000 Hearthstove - Flue Connection](https://www.hearth.com/talk/data/attachments/231/231459-6ad1e241ca1fe68257fae9008babc20e.jpg)
I have a Sierra Classic 2000 Hearthstove (rear exit) and a masonry fireplace with a tile flue. Picture of my unit on the brick hearth. It is identical to this one https://www.hearth.com/talk/threads/sierra-hearthstove-classic.111947/#post-1487301
Right now the stove vents to the masonry fireplace which is sealed off with the factory metal cover plate. The damper plate is removed at the top of the masonry firebox. From reading here on this forum, this is what is called a "slammer" and is not desired. My parents had this exact model stove installed in this same manner for more than 25 years without issue but I am looking to do this right.
The manual makes reference to a damper adapter yet I have not found one. From reading this forum, this approach is what some refer to as direct connected? Where would one obtain this adapter short of custom making one? I suppose I could make one from metal plate cut to match the damper assembly (overlap the hole) and make clamps to bolt it in place. Then the issue of connecting flue pipe to it and the stove while snaking thru the factory metal cover plate.
I am thinking the best approach is a flexible stainless liner connected to the stove. I found this link to be most like what I am thinking however I want to keep the cover plate in place to conceal the masonry firebox opening. https://www.hearth.com/talk/threads/rear-vent-wood-stove-through-masonry-fireplace.110725/
Is the Tee at the bottom needed? The manual excerpt just shows an elbow and a downward slope to the stove.
