Here's what this customer has.
Isle Royale Stove
Connector pipe is Simpson DVL. double wall air cooled.
Chimney is Simpson DuraTech Class A, double wall insulation packed.
Vent goes off the stove up about 4', 90 elbow and horizontal about 2' through the wall (outside) into a T
Chimney then goes straight up 26' all exposed outside with the standard cap on top.
About 10' of this is above the roof, it looks like it goes above the peak.
From my experiences here I think this should work fine.
Here is the concern, when the stove is going good and hot and they open the doors to load, they get smoke back into the room. They have a stove top temp guage and run it around 400-600 usually. If they try to open to top loader door they get smoke back. This is a very old house and thus, is not sealed up the greatest. I really doubt there is any sort of pressure issues in the house. When they had the chimney swept the sweep noticed a lot of buildup where the horizontal piece comes off the T. He thought there was air leaking in at this point and cooling off the flue. I took the stuff off the bottom of the T and looked up in there and the horizonal section is not fully engaged on the left side (where the supposed buildup was). I could not feel any gaps but I could see where one side was in further than the other. Is this a legit concern? I am hoping to correct this but I'm not sure what kind of trouble we will run into. Any ideas, thoughts, suggestions, welcome.
This is in Wisconsin, and obviously the problem is from last burn season, they are not using it yet this season.
Before you ask... I have pictures but I don't really want to post them on here. I could share them with someone privatly if you are that interested.
Isle Royale Stove
