Last year I ran the oil burner with a coil to heat my DHW.
I finally got an indirect DHW hooked up in the middle of this season.
It is a Superstor Contender with a 50 gallon tank. I have it set to 125* and there is no differential setting.
Quite honestly I didn't really pay attention to how long it would take to charge. Until now.
I haven't needed heat for the past two days so I've been more in tune to the need for DHW.
I changed the setting on the aquastats, I raised the high limit to 200* with a 30* differential.
I lowered the low limit which turns on the oil burner to 100*
I lit a small fire in the morning and when it reached temp I shut it down.
There was enough demand yesterday and more to come in the evening with showers that I decided to light a small fire at 7pm and brought the boiler up from 140* to 200* and shut it down.
It was 11:30 pm when I finally took a shower. I was laying in bed and could hear the low hum of the circ pump for the indirect. I woke up at 12:30 and it was still running. I went down and killed the power to the circ.
This morning the boiler was down to 140* so I light a fire at 5am and turned on the circ pump at the same time. The boiler reached 200* and shut off but the circ kept going for more than an hour.
Same thing tonight, boiler was down to 130* and after washing a few pots from dinner the zone was running continually for almost an hour.
Is that normal or is my plumbing wrong.
I'm still not 100% convinced that my primary/secondary loop (or injection loop as someone said) is plumbed correctly. Maybe that is the cause. Or maybe the 60 feet of 1" pex from the boiler to the loop isn't large enough. I can only imagine how ineffecient my heating is based on how long it takes to bring the tank up to temp and how much extra wood I might have burned![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
