Some of it will be enclosed in a direct vent bump out and about 20' of it will be exposed. Doing the job in Stainless will cost me ~$400 more. Money is definitely an issue but I don't want it to cost me more in the long run.
i would & keep extra paint on hand in case it peelschris-mcpherson said:That's what I thought about the integrity of the galvanized but, I have a supplier pushing the stainless with it's rust and corrosion resistance properties. I thought galvanized would hold up just as well. I figured it was an issue of aesthetics only.
Would it be advisable to paint galvanized pipe? If so, I could paint it the color of my house.
Damn good point.tiber said:I don't want a blinding obilisk of light
chris-mcpherson said:Oh yeah...didn't think of that. Any idea what the approximate temp would be over half way up a 26' run would be?
chris-mcpherson said:I was referring to the type of paint to use. Am I limited to hi-heat stove paint?
DAKSY...what part of NY are you at? I grew up in the Adirondacks.
pen said:This is the part of the stainless steel spec sheet from simpson
Cost for this pipe is 172.97 from http://www.ventingdirect.com/simpso...ess-steel-class-a-chimney-pipe-length/p656032
Specifications
Material Specifications:
Outer Wall: 430 G-90 Galvanized Steel, .016" Thick, or .021" Galvalume Steel
Inner Wall: 430 Stainless, .020" Thick.
Insulation: Thermal Tech Blanket
Misc:
Maximum Temperature Rating: Rated for continuous use at 1000°, intermittent use at 2100°
Supported Fuels: Wood, Oil, and Coal
Warranty: Lifetime Warranty
UL Listed: 103HT, 103
Here it is for the galvanized
The cost is 142. 70 http://www.ventingdirect.com/simpso...alvanized-class-a-chimney-pipe-length/p656033
Specifications
Misc:
Are these spec sheets wrong? Other than the 30 dollar difference, I don't see what the heck the difference is? This is the same spec sheet that pops up for these products on other sites as well. I'm confused.
pen
Materials and Construction: Inner wall of 0.020" 430 stainless steel. Outer wall options of 0.016" 430 stainless steel or 0.021" galvalume steel
chris-mcpherson said:I cared a little bit what a galvanized chimney would look like but in the end, the money savings meant more. I'm glad I decided to save the money because even though it's on the side of the house with the driveway... unless you mean to look at it, you don't even notice it. I have a feeling that a shiny SS chimney would have stuck out like a sore thumb.
I've also seen nothing that says galvanized MUST be painted... only tips on HOW to do it if you want to.
pen said:So the stainless pipe is stainless inside and out and the galvanized pipe is stainless only on the interior?
If so, and you don't mind the appearance, they both seem to be rated equally each with a lifetime warranty. I guess it depends on how much aesthetics matter to you.
LLigetfa said:I've seen enough cheap class A chimneys rusted away that I would never go that route. Forget about those supposed lifetime warranties where inferred quality is implied. They are all about marketing. Good luck ever getting satisfaction on a claim.
