Hi all, I’m fairly new to wood stoves and moved into a house last year with an Avalon Rainier wood stove insert. It wasn’t in the greatest condition but we cleaned it up, replaced the baffles and air tubes, new glue liner, etc. and got it working pretty well. The only issue is that it sometimes overfires even with the air intake closed down all the way. The gasket is in pretty good shape and I did the dollar bill test, which it passes.
I found this small crack on the side of the door, and it appears to be a crack in the cast iron. Is this the source of my issue? Wondering if it would be better to just get a new wood stove since I’m not sure how old this one is or how the previous owner operated it. Or is this salvageable?
![Should I replace this door? Should I replace this door?](https://www.hearth.com/talk/data/attachments/305/305532-adee2b95d20823b93d4bafb644ce216d.jpg)
![Should I replace this door? Should I replace this door?](https://www.hearth.com/talk/data/attachments/305/305531-157e08b2cd7de24b3e2c6b6792e527d8.jpg)
