Hello, this may be a little long lol.
We are doing much better with dryer wood this year, and if we really keep it rolling along we can get good heat to spread over almost the entire house. We use a thermostatically controlled electric heater in the one far room (right above stove) we don't get much heat in. The only "problem" we have is we can't seem to get it over 500 if that. We have gotten it to 600 once, ever. The manual for our stove says to keep it in between 4-600. I was thinking if we could get it to push into the higher end of that scale we would get more heat out of our setup.
I am thinking that we may not be generating enough draft. Unless I am mistaken a longer chimney would be a bit harder to get a cold start going but would draw harder once going. Last year we had pretty damp wood and were new at this so we had some beginner issues getting the draft going. These days we can get it going with zero effort, almost immediately. I know I don't need it crazy hot to get secondary burns. We get them going as low as 400, but I was wondering if we couldn't get a bit more out of it while staying in the recommended range.
The advice I was given on the chimney last year was that it is a bit short. I have an extra 4ft piece I could put up to add length or cut to add a bit less. You guys recommended adding it, but I felt like it was doing ok so I waited. The guy from company that came to clean and inspect said that 4ft more would be more than he would recommend and said to cut it at 2ft. Does 2ft make that big of a difference?
I know I am losing a lot with it being by an uninsulated, free standing, slab wall. Believe it or not though, after it saturates, it does spread to the rest of the house slowly. It takes forever, but once it's warm you can maintain it. Anyway here is the stove pipe setup.
The stove pipe is double insulated and the I.d. of both the stove pipe and the chimney is right about 6".
Here is a pic of the chimney.
The chimney height is about a foot taller than the required 3 ft past where it clears the roof. However it is just a few inches short of the recommended 2ft up from the roof; if you measure 10ft over from the highest part of the chimney.
As far as total chimney height the full length pieces are 4ft x2. There are 2 half pieces, so 2ft x2. And then the bottom clean out, and 2, 45° pieces are like 1ft x2. So without measuring I would say 14ft and a few Inches tall. I live on a pretty steep hillside of a small valley if that is a factor.
Anyway I guess before I climb up on my roof and add either the 2 or 4ft piece I wanted to see which you guys think is better because I do not want to have to change it again. Am I mistaken in thinking it would draw harder with a bit more length?
B.t.w. I am happy with the location, it really does a pretty good job there already and when I need to help get the draft going I can crack that door. The basement is an area we do spend some time in, as our bedroom is, and someday the living room will, be down there.
My last 3 posts on this thread will tell you a lot about how it has burned for us temp wise in the past.
https://www.hearth.com/talk/threads...stall-it-like-this.117482/page-2#post-1827122
![Should I add more chimney? Should I add more chimney?](/talk/proxy.php?image=http%3A%2F%2Fi1222.photobucket.com%2Falbums%2Fdd489%2FOutkastboss%2FYotul%2520Stove%2Finsidestovepipe_zpsc455a12b.jpg&hash=292c0acde3f7110ac3cdaa546bbd6233)
![Should I add more chimney? Should I add more chimney?](/talk/proxy.php?image=http%3A%2F%2Fi1222.photobucket.com%2Falbums%2Fdd489%2FOutkastboss%2FYotul%2520Stove%2Foutsidechimmney_zps0af917a9.jpg&hash=ee7f059555399d7d79b123becfa741f3)
