Webmaster said:Those tall legs are well above NFPA guidelines, and I suspect a lot of the reason is just to get the stove up to a more comfortable loading height.
BeGreen said:Matt, just curious, why the shorter legs?
If the 2" shorter legs work for you, that's great. But you may want to boost the hearth protection a bit. The 602 can get plenty warm at times. If you already have a well protected hearth, you should be all set.
stoveguy2esw said:BeGreen said:Matt, just curious, why the shorter legs?
begreen has a point , jotul's do a great job radiating, make sure that they are rated with shorter legs as well to satisfy code. dealer should be able to provide info on that. its a nice unit by the way a friend of mine has one and is very pleased with its look and function.
mattg1970 said:I actually found that jotul dealers sell 6 and 4 inch legs for the f3 stoves. The legs may be interchangeable but I haven't taken off one of the 602 legs to match it up yet. When i do I will let you know if they are the same.
