Shop Vac Bearings Replacement
Whitenuckler
111
PEI Canada
Hi - I recently took home a shop vac SVX2 12 Gal 5.5 HP someone had put curbside. The motor was working but grinding. I took it apart and found the fan end bearing blown. I ordered a 10pac of 608 RS bearing and a puller. I replaced both bearings. I am not sure how well the fix will turn out as the armature had been grinding on the stator. I will update later.
  • [Hearth.com] Shop Vac Bearings Replacement
Reactions: Dajolu
Got it back together. I now have a large shop vac for the garage. Just need to have a filter for it. Have 8 spare bearings left and now own a puller which I never had before.
  • IMG_3892.MOV
    7.1 MB
Don’t use it for water if you have to lift it to empty! That’ll be heavy when full!
I believe the person that put it curbside was a plumber, as there were no filters, and all the screws totally rusted. You would think that if you used it for waster and sand, then after you would dry it out after. Some have a bottom drain. I'd have to check this one. Also, if you bring the water level up too high, there is more chance of it getting to close to the fan. The fan is aluminum, but right above it is the motor.
