Hello all. I wanted to post a little about this furnace because when I was looking for reviews on it I couldn't find anything about it. Previously I was using a Drolet Tundra which had some cracking issues and SBI was kind enough to give me instore credit so I decided to buy the Shelter furnace because I wanted to start burning coal also. The Shelter furnace is built very well with thicker steel when compared to the tundra and the welds are much thicker, the way it is designed even at full on burn the sides are cool to the touch so the fire box retains a lot of heat. This furnace is made by HY-C which is built in the USA and they also make the Fire Chief brand furnaces which are basically the same design, but they have a few minor changes and longer warranties. The furnace comes with a 3 speed blower which is actually adjustable by a knob, whereas the Tundra you had to move a wire. The Shelter has cast iron shaker fire grates, an ash pan, a draft inducer and a secondary burn chamber which actually does work because I can see the flame going in there and no smoke coming out the chimney. The furnace when reloading will smoke for about 20 minutes, but once it is hot enough and you push in the by pass lever there is usually no smoke coming out the chimney. I know the furnace isn't an EPA like the Tundra, but when I called and spoke with Shelter they said they will be having them tested soon to comply with the new regulations. The shelter rep that I spoke with was very knowledgeable about the furnace design. The draft inducer even though mounted over the fire it has a front plate in the firebox that diverts some of the air under the fire which helps with burning coal. I am heating my main floor and my basement which is about 1900 sq ft. I over sized the furnace because I can always build smaller wood fires. It has a very large firebox and can take up to 28" long pieces of wood and will handle about 50 pounds of coal. While burning wood I have been getting 12 plus hours of burn time while using white ash and sometimes a half log of coals are left before I refill. While burning Anthracite coal I have been getting 24 hour burn times with about 20-25 pounds left for refill, if I let the coal burn completely out it would be about 48 hours of total burn. Here is a couple pictures. I have a plenum mounted on top of it that is then fed into my existing lp furnace plenum.
![Shelter SF2631 Wood Coal Furnace Shelter SF2631 Wood Coal Furnace](https://www.hearth.com/talk/data/attachments/156/156878-bbd88e87bad9a87b10df1bfe0ed7b723.jpg)
![Shelter SF2631 Wood Coal Furnace Shelter SF2631 Wood Coal Furnace](https://www.hearth.com/talk/data/attachments/156/156877-dfd220917066b98a398b8fd1efcd0178.jpg)
