Does anyone have a source for the flat sheet gasket used on these stoves? I was looking at this one: http://www.mcmaster.com/#standard-gaskets/=fo76zj (item #95715K62)
It is rated to +850*F. I have two cleanout doors on my stove that I remove regularly, and the gaskets are already getting quite ragged. They are the white fiberglass type stuff maybe 1/16" thick. Also the baffle plates behind the "firebrick" facade have 1" strips of gasket material on them that will need to be replaced upon next dis-assembly.
What temp do you think these gaskets need to withstand?
Thanks in advance for any advice!!
