settings
hopper
2
canada
my whitfield pellet stove does not seem to be feeding pellets properly as i get a build up of pellets faster than the burn rate.what should the setting be for the combustion air set at and what should the setting for the feed rate be set at before adjusting the damper control .the stove is a whitfield advantage II 1990 model .
thank you
Try slowing down the feed rate or trim rate. That worked for me.
thank you
Welcome to the board.
To get more people to look at your post explain a little more in the title such as "Problem with Whitfield stove settings". "settings" does not say much. Rod should answer on a Whitfield.
Eric
