Hello
I have a Seton W-90-E Wood Boiler Serial 01211 built at the time by Bethel Engineering & Equipment at the time. It has worked well, replaced to skins with stainless steel over the years, and aquastats. It has heated with my house since 2009, at one point I went 10 years without buying oil. Many years I used the boiler all summer to heat water water.
Recently the Heat exchanger has failed. I believe Fred passed away, Bethel Engineering no longer makes the parts. Does anyone have any idea if any companies still sells the heat exchanger, maybe a dealer out there might have some left over... Any of the other folks that may have built the boiler over the years...
Would have been nice if the originals were built in stainless steel, would have held up much longer.
I live in NH, a solution within a 100 miles would be helpful, but open to all thoughts/suggestions.
Looking for suggestions.
Thank you,
Larry
Thank you,
Larry
